clare weeks
Can import dwg. to Vectorworks 2017 but can't edit
We have successfully imported a dwg. files into Vectorworks at the correct scale 1:50 and saved it.
However we cannot edit the content (2D floorplans).
When we click on the objects within the file they are locked in an orange tinted box with the error message "The selected object has no edit behaviour".
Any advice on how to unlock and edit gratefully received.
Clare
12 answers to this question
In the top LH corner above Class there will be some text in bold which says what type of object it is when it is selected.
A successfully imported DWG will have a Design Layer which is the name of the DWG you have imported.
Open a new drawing and then use the Import Single DXF/DWG command (File/Import... menu) to import the DWG into that file.
We already did this. Created a new file, imported single dxf/dwg file, saved as vmx file, but the content is non-editable (in orange box). Any ideas? Is there something on the import options menu that we should be checking?
When you import a single DWG/DXF, a dialog box should pop up. On the Primary Settings tab of this dialog box, make sure the "Reference" box at the bottom is unchecked. This should directly import the dwg and allow you to edit it.
Make sure that after importing you aren't just looking at a Sheet layer (Paperspace in DWG terms) with a viewport of the geometry, make sure to switch over to a Design layer so that you can select and edit objects individually.
Still having issues with this file : (
See screengrab image.
In the OIP the file is shown as DWG - Referenced. This I think is preventing us from editing the content (although we can see of of the plan drawings).
If I try and import the dwg. without checking the "Reference" option we can only view the first drawing in the dwg. file.
If I import and check the "Reference" option we can view all plan drawings but can't edit.
The layer is set to "Design Layer".
What are we doing wrong?
Hey did you figure this problem out? I am having the same problem.
Can an anyone else help? I have spent hours trying different import options. It appears to be coming in as a locked viewport.
I am also having this exact same problem; has anyone worked out what is wrong?
I've spent hours trying to sort it out.
Can anyone help?
When you initially import the dwg, ensure that in the dialgue box that appears, that the 'reference' is unticked about 3/4 down the page; it will then import as normal.
