Get WS Cell Object Handle
You could possibly use a =RunScript function with a short Vectorscript or Python Script. You can use the WSScript_GetObject command to get the handle to the object that  the subrow is referencing.
I don't think you can get an image out of a cell. The subrow functions only appear to allow you to GET stings or values.
The function that I am wishing for is a way to get the cell a RunScript function is in when the script is activated so I can do relative cell references.
Let us know if you need more help.
Thanks pat.
I needed some attempts to get back from the str to the vs.Handle.
The cells get filled with this code:
h = vs.WSScript_GetObject()
h_str = str(h)
vs.WSScript_SetResStr(h_str)
Then another script iterates trough all objects and compares the handle strings:
def get_handle_from_str (h_str):
	h_dict = {} # key: handle_str val: handle
	def collect_handles(h):
		nonlocal h_dict
		h_dict[str(h)] = h
	vs.ForEachObject (collect_handles, 'All')
	try:
		h = h_dict [h_str]
	except KeyError:
		print ('Handle could not be found.')
		h = None
	print (h_dict)
	return h
# EXAMPLE
h = get_handle_from_str ('AEC62080')
vs.SetSelect (h)
It's kind of unpracticle and carries the risk if inconsistency but it works.
ws_test.vwx.zip
Patrick,
I would be careful  with what you are doing. It looks dangerous to me. Also, I think the string you are returning is not the full handle. When I use VectorScript to get the handle as string, I get a different value even after accounting for Python returning the value in Hex and VS in decimal. It appears that Python is leaving off the top 4 hex digits.
But let's step back from there.
What data do you have in the database row that needs to be written to a record? Since all the data is coming from records already, why do you want to put a copy (with potentially obsolete values) into a record?
There is probably a reason, but if you tell us what you are really trying to do and why you think you need to do it we might have a better solution.
  • 3 years later...
