VW Crash when plugin object has UI override and radio button value is changed
Hi, wondering if anyone has encountered this or knows of a solution:
When I enable custom object info palette for a plugin object with
 vs.SetObjPropVS( vs.kObjXPropHasUIOverride, True ) #8
I find that trying to change the value of radio buttons in the object info palette crashes vectorworks.  I have inserted all of the widgets with
vs.vsoInsertAllParams()
I'm not trying to do anything crazy; I am really just trying to get some separators onto the OIP.  I am handling Event 41 as guided by the wiki:
elif theEvent == vs.kObjOnWidgetPrep: #41
        UpdateParametersState()
def UpdateParametersState():
    vs.vsoSetEventResult( vs.kObjectEventHandled ) #-8
Changing the value of other parameters in the OIP, including numeric fields and checkboxes, works fine.
Most importantly, I see the same behavior when I try the example plugin provided at http://developer.vectorworks.net/index.php/Python_Sample_Point_Object_(complex)
If I click the radio button for Male / Female in this PIO's info palette, vectorworks crashes.  This leads me to think there is more going on than bad code in my own object.
I am running VW2017 SP4 on Mac OS X El Capitan
  • 2 weeks later...
The other workaround is to turn off developer mode when you're testing radio buttons.  It's always a bummer when you forget though...  I finally hunted down a VW plug-in that triggers this behavior, and this is slated for a fix.  Possibly not until 2018, though.
-Josh
