Ivan Ferris
Renderworks not working!
Hi
I'm having a issue, with renderworks in vectorworks 17, when I click on "new renderworks texture" nothing happens, the hinks about it for a while then nothing no dialogue box appears like it should! I can attach pre-loaded textures from the classes menu, but when I right click in resource manager and click edit not happens...I can only render hidden line, open GL and final shaded styles, nothing more advanced than that... its a brand new programme only uploaded a month ago and this is the first this I tried to render something and nothing is happening! It feels like I don't have renderworks in my version at all. I can open a view port put it to final quality renderworks, then update rendering in the view port and nothing happens. I am running Fundamentals Architect Renderworks. Please help!
Ivan
4 answers to this question
Was Renderworks ever working properly on this machine, or did it fail the first time you tried to use it?
Also: what operating system are you using, and which service pack of Vectorworks 2017 are you currently on?
This is the first time I've tried to use the renderworks, so its never worked! Its a brand new laptop and brand new vectorworks 17. We're running on window 10.
Check your work space, you can find it in extras..i think on the bottom. change there to another one and see if that makes it better.
This issue has appeared for a few users, normally an uninstall/reinstall will cure it, but tech@vectorworks.net may have a cleaner solution.
