When duplicating sheets, the sheet number in the title block should auto-update. It used to but now you need to force the title block to update by editing and then cancelling.
When duplicating sheets, drawing numbers in the Drawing Label PIO should not change on the new sheet. I want an exact duplicate of the sheet I'm duplicating.
Sheets should correct when there are multiple drawings with the same number. Duplicate numbers are created by #2 above.
Sheets should have a hidden ID number that relates to the sheet in the Publish dialog. When I rename a sheet I shouldn't have to remove and re-add it to the publish list.
There should be a way to auto number Drawing Labels (eg. top left to bottom right, either going across first or going down first and then stepping to the next row or column).
Many of these issues are bugs introduced in VW2016 and VW2017. They really play havoc with efficient workflows that involve duplicating Sheets and Sheet Layer Viewports. I'm tired of proofing published PDF only to find I have to recreate them because I missed something that shouldn't of happened in the first place. Its taking up a lot of resources on my end.
Kevin McAllister
Please fix drawing co-ordination, including -
Thanks,
Kevin
10 answers to this question
