AlanW Posted June 23, 2017 Share Posted June 23, 2017 Hi, Looking at the set height node and wondering how to get it to operate. tried a few options but I cant seem to get it to alter the object. What am I dong wrong. Thanks 170624_Set Height Node.vwx Quote Link to comment
Kevin McAllister Posted June 24, 2017 Share Posted June 24, 2017 I gave it a try Alan but didn't have any more success than you did. I tried using the "Get Height" node to see the value it was trying to alter. It seems like "Get Height" returns the Delta Y value of the object (not the Delta Z value). So in your example, it returns the diameter of your circle, not the height of your extrude. "Set Height" doesn't seem to alter that value. The developer info on the underlying Vectorscript command vs.SetHeight isn't very helpful either. This is why there needs to be proper documentation..... Kevin Quote Link to comment
Marionette Maven Marissa Farrell Posted June 24, 2017 Marionette Maven Share Posted June 24, 2017 Kevin is correct that Get/Set Height refer to the Y value of objects, not Z. I'm not at a computer with VW at the moment, but I believe in the "Object Info" category there is a node that should return Top and Bottom Z values. To get your overall Z height, you would want to find the difference between those values. Hope this helps! EDIT: You also may be able to use the Get 3D Info node in the 'Object Info' category? Again, not at VW, just trying to think of what's available from memory Quote Link to comment
AlanW Posted June 24, 2017 Author Share Posted June 24, 2017 (edited) Doh, I knew that. Been on holiday mode too long. width and height always relates to X & Y. Soon as i put a rectangle in and the height changed to the set height node input. Edited June 24, 2017 by Alan Woodwell 1 Quote Link to comment
