We really, really need improvements to way roofs join to other roofs or slabs so that these display correctly in section views.
We typically do lots of roof top extensions which normally require a roof with 2 or 3 different pitches as per the attached image. It's currently taking us a massive amount of time to get these to join correctly in section view when we take a cut from the 3D model. Even then we're left with junctions that require additional 2D work to rectify. This is even without us showing all the individual components.
We really need 2 or more roofs of different angles on the same "slope" to be able to join together so that the structure, finishes etc. can be run continuously. If roofs could interact with each other similar to how walls interact with roofs then it would save us a tonne of time and give us a more realistic output to boot. As you can see from the attached image we're left with pinch points at the junctions which don't reflect how this would actually be built.
whashisface
Thanks in advance.
0 answers to this question
