Wish = enabling setting different colors to classes as it is still there for design layers and a nice simple button in the View Bar.
I make a suggestion in the picture below.
+ The different colors are only necessary for proper drawings, not for the output. It would help you to draw things on the right class and you can search for elements on the wrong class by press the new "use class color" button .
+ when you work with other offices and technical designers, you often get files to import or to check up. With this viewoption, you would could easily see the different parts on different classes, even if they are black lines or colored from the owner. The advantage is, that you dont interfere in the class-styles or colors from the original designer!
schsch
1 answer to this question
