TArchit Posted June 8, 2017 Share Posted June 8, 2017 (edited) Column objects are disappearing when I combine them into symbols. Why is this happening and is there any way to resolve it? They are showing up in 3D in wireframe but not in plan. Thanks in advance Edited June 8, 2017 by TArchit Quote Link to comment
michaelk Posted June 8, 2017 Share Posted June 8, 2017 Can you post an example of the symbol? I use column objects in symbols all the time and I don't see them disappear. Quote Link to comment
TArchit Posted June 8, 2017 Author Share Posted June 8, 2017 Sure, here you go... column symbol.vwx Quote Link to comment
Kevin McAllister Posted June 8, 2017 Share Posted June 8, 2017 The Square Tubing PIO you're using as your columns is 3d only. It doesn't have a hybrid component to appear in Top/Plan view. Since your walls have both a 2d and 3d component VW makes your symbol into a hybrid automatically. Try using a different PIO such as the Column Tool or the new Structural Member tool. Kevin 1 Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted June 9, 2017 Vectorworks, Inc Employee Share Posted June 9, 2017 Yes. The Column tool (as Kevin suggested) would be best. These objects have both an Architectural component and Structural component. You would only need the Structural component (which can use the steel shapes). Quote Link to comment
