line-weight Posted June 9, 2017 Author Share Posted June 9, 2017 11 minutes ago, bcd said: a extract of the solid intersection between and extended baseboard and a solid addition of the stairs I'm not quite sure what you mean by an "extract of the solid intersection"? Quote Link to comment
bcd Posted June 9, 2017 Share Posted June 9, 2017 You should probably do this on a duplicate. Select the stair parts - Add Solids Extend the baseboards so they penetrate the stairs, select them, Add Solids Select both solid additions, Intersect Solids Use the Extract tool to extract the surfaces of the intersection Unfold the surfaces and align them as I've done. This will allow you to work on the actual developed intersection of the stairs & baseboard. Quote Link to comment
line-weight Posted June 9, 2017 Author Share Posted June 9, 2017 21 minutes ago, bcd said: You should probably do this on a duplicate. Select the stair parts - Add Solids Extend the baseboards so they penetrate the stairs, select them, Add Solids Select both solid additions, Intersect Solids Use the Extract tool to extract the surfaces of the intersection Unfold the surfaces and align them as I've done. This will allow you to work on the actual developed intersection of the stairs & baseboard. Ah thanks, now I get you. Wasn't sure what you meant by baseboard, I see it's the american term for what we call the skirting or stringer in the UK. Quote Link to comment
preston bircher designs Posted September 16, 2019 Share Posted September 16, 2019 On 6/8/2017 at 4:46 PM, Alan Woodwell said: This is a method I often use for the stringer of a curved stair. See ozcad tutorial @Alan Woodwell thank you for posting this vid... it answered ALL of my questions! Very helpful! Quote Link to comment
