Hello,
I have been experimenting with rendering gobo recently. And I seem to get a ring of light spill around the shape of the gobo. Is there a way to fix/get rid of this? Please see the image below to see what I mean.
Also, the breakup shapes seem to be really low quality. Is there a way to fix this?
Thanks,
Ryan
You can use the Gobo Shift parameter to adjust the location of the gobo and eliminate the ring.
Is it possible for the GOBO SHIFT parameter to be added to the EDIT INSTRUMENT dialogue box?
The gobo is a texture resource.  You can edit the texture to adjust the scale as well as substitute in a higher resolution image.  This is also the only way to take the projection out of sharp focus: edit the texture image in an image editor.
-Josh
-Josh
Josh is spot on with this.  I HIGHLY recommend copying an existing gobo texture and learn how to edit it.  It is quite simple.  To that point I have created my own library of gobos simply because of the ring, the resolution and the fact that there is no control over the edge focus.  Once you see how to do it, the process is very simple.  I am attaching an image of both a hard and soft edge gobo in use.
Edited by scottmoore
Thanks for your help. Yep was easy enough to blur the texture in Photoshop and have started to create my own library of gobos. Here is my result:
How do you get the beams to be broken up? Is that using in VW or a a separate program?
EDIT: Figured it out. Needed to check receive shadows in background options.
Edited by mreadshaw
