Door & Windows Tag Visibility
Hi SunnyFIsher,
Sure you can. In the "" tab of the Settings dialog, give the tags a particular class (I think there is a preferred class of 'Door-Spec' and 'Window-Spec' for this.) Then just hide that class in the viewport settings.
HTH, Robert
  • 9 months later...
Guest Blars
I am having a problem with window tags being visible in my 2D building elevations.  The sides of the building show the window tags as lines held off of the building wall (probably because of the window sill extension/drip)  Is there a way to turn off window and door tags when the window is not seen in the elevation?
Thanks
