  • 4
markdd
Spotlight Instruments and OpenGL shadows
I often want to see shadows from Spotlight Instruments in OpenGL. This is currently not possible as Open GL sees the texture applied to the object as solid and does not allow light to pass through. It would be terrific if VW engineers could find a way of enabling the "does not cast shadow" functionality for a named texture in OpenGL so that we can use instruments to check shadows and shutters etc.
Thanks
Mark
8 answers to this question
The problem is that the texture we apply that allows the light to come out of the geometry would not let the light pass out of the fixture then.  worst of both worlds.
Hence the Wishlist item.
As you can see my post asked if this could be made possible. It would be so helpful to see shadows. Its not always about the beams!
I agree, and did give it a vote.  the problem currently is that you need the texture to have the lights that are on work, but you can't change the texture because then you don't have lights to test if they are hitting something or not.  bad catch 22.
I've discovered a workaround this morning. I class my instruments so that the 3d portion is in a separate class. What I have discovered is that if you change the class properties of that class to "no fill", then even though the texture is there it doesn't block the emitter locus and voila you have a beam to use that emits shadows. So the workflow is simple. Just toggle the 3d geometry class to no solid, refresh the instruments and then you can see the beams in OpenGL with shadows!
Open_GL_Shadows.vwx
Edited by markdd
Mark,
How did you set up the Light-3d class to allow for the shadows.  I tried to set up a class for an instrument, as you appeared to have done, yet no luck with shadows.
Tim
Go to your instrument symbol and go to the edit 3D portion
Put all the 3D geometry into separate class; say, “Lights-3D”
Make sure that the geometry is all set to inherit Class Attributes.
Then go to the edit class dialogue and set the fill for that class to None.
After you refresh the instrument/s you should be left with an open wireframe instrument in OpenGL with shadows enabled. This means that the instrument will now allow light to pass out from the locus point to the focus point and you will see the beam on any 3D surface. Enabling shadows in OpenGL means that you will also see the effect of shutters and gobos as well.
The reason this is necessary  is because OpenGL does not “understand” the “cast no shadows” nature of the default Lighting Instrument texture which is read by Renderworks.
Hope that hat makes things clearer.
Open_GL_Shadows.vwx
So Mark: This notion has captured my interest. So how do you class the 3D portion of the fixtures? D'you create a separate library, with all your re-classed fixtures or other technique?
-Thanks-
@mjm Yes. I have for years kept my own library instrument symbols. Some have been made by me from scratch and some are adapted from stock vwx symbols. All are classed as follows:
  • Lights-2D (for the 2D TopPlan shape)
  • Lights-Info (for information such as beam angle or other text)
  • Lights-Movement Radius (For the movement radius of moving lights)
  • Lights-Col (For a circular disk that I set to show Gel colour in 2D as well as represent the lens geometry in 3D. This uses the "modify lighting instrument colour" portion of the Spotlight Preferences dialogue)
  • Lights-3D (For all the 3D geometry (apart from the lens))
It is the Lights-3D portion that I set to No Fill when I want to see beams in OpenGL with shadows enabled. However,  as the stock vwx symbols are classed Lighting-Incandescent; Lighting-LED; etc These could just as easily be set to "no fill" and the same principle will apply. It's just that the 2D Top/Plan representation will have no fill as well while you work on your beams/shutters/gobos etc in OpenGL.
