Tmotions Posted June 4, 2017 Share Posted June 4, 2017 Dear community. I have some trouble figuring out how to paint specific parts of my interior design. I need some parts of the wall to be painted differently like if you would paint the surface in real life. Is there a tool to just put colors on a selected surface. (school project) Please share your knowledge. Thanks Quote Link to comment
mike m oz Posted June 5, 2017 Share Posted June 5, 2017 You need to apply Renderworks Textures to the walls. If there is part of a wall that you want a different colour you can do this with a Decal. 1 Quote Link to comment
AlanW Posted June 5, 2017 Share Posted June 5, 2017 If one wall has different parts coloured extract sections of the wall surface and nudge them off the wall by a small amount then paint that section. 1 Quote Link to comment
Jonathan Pickup Posted June 5, 2017 Share Posted June 5, 2017 Alan, i thought you might have suggested a marionette solution. I would have suggested the extract option. 2 Quote Link to comment
Tmotions Posted June 5, 2017 Author Share Posted June 5, 2017 Nice it work's. Thank you for the greate tips ! Quote Link to comment
barkest Posted June 5, 2017 Share Posted June 5, 2017 It depends on which parts of the walls you need to paint separately. Think of it this way: If I asked you paint a wall in a room you would ask two questions: 1. Which wall 2. What colour VW is no different. Select the wall and go to the render tab in the OIP and here are the two questions except its which part (there are seven parts to a wall) which typically will be left or right (depending on the direction you drew the wall) and then which texture. As for the separate parts then you have a horizontal or vertical. The vertical can be taken care of by selecting the wall and using the split tool (in line mode) making sure you have the wall selected and you choose split selected objects option. For the horizontal the extract tool will do this (create planar objects) but when you adjust the extraction make sure you double-click and adjust with the tools otherwise you will distort the extraction. When complete extrude by 1 or 2mm to suit. 1 Quote Link to comment
Raj Posted March 24, 2018 Share Posted March 24, 2018 Hi, How to create Wall like attached model ? Quote Link to comment
Marci Posted May 20, 2022 Share Posted May 20, 2022 I wish you could apply images (eg. for wallpaper) as easily as textures! It's not often I'm applying a texture. I end up creating a rectangle with an Image fill, but then have to spend time punching out the holes for windows and doors. Not sure why VW doesn't let you apply Images in the Render tab of the OIP. And to my knowledge, you can't add an Image as a Texture in the Resource Manager (Textures don't seem to allow uploads when creating a new one). Quote Link to comment
jeff prince Posted May 21, 2022 Share Posted May 21, 2022 18 hours ago, Marci said: I wish you could apply images (eg. for wallpaper) as easily as textures! It's not often I'm applying a texture. I end up creating a rectangle with an Image fill, but then have to spend time punching out the holes for windows and doors. Not sure why VW doesn't let you apply Images in the Render tab of the OIP. And to my knowledge, you can't add an Image as a Texture in the Resource Manager (Textures don't seem to allow uploads when creating a new one). Wallpaper using textures, as easy as this example is tacky 🙂 You can make your own in moments or use the built-in wall covering textures as a basis from which to begin. Sure beats trying to position decals and cutting out doors and windows manually. 2 Quote Link to comment
