Kurt Ofer Posted February 7, 2004 Share Posted February 7, 2004 I just installed 10.5 on G4/400/900MB RAM and got the message at the very end of the install, "there was an installation error and the installation is not complete." So I launch 10.5 and it says it is in Demo Mode. I quit the installer. What do I do now? Kurt. Quote Link to comment
Guest Posted February 9, 2004 Share Posted February 9, 2004 You can try to copy the installer from the CD to the desktop and run it from there. Or you may have one of a few bad 10.5.0 CDs. Contact Customer Service at 888-646-4223 to request a new one. Quote Link to comment
Kurt Ofer Posted February 9, 2004 Author Share Posted February 9, 2004 Thank you. I just requested a new CD. Now what do I do with what has already been partially installed? Do I just throw the VW 10 file away? Are there any system level files that I need to delete also? Is there an uninstaller? I just would like the satisfaction that the upgrade was properly installed without duplicates which might cause problems later. Thanks again. Kurt Quote Link to comment
Kurt Ofer Posted February 10, 2004 Author Share Posted February 10, 2004 You should also understand that this occurred with VW 10.5.1, not 10.5.0. Quote Link to comment
Guest Posted February 10, 2004 Share Posted February 10, 2004 Delete the VW folder and the VW PRefs file. You didn't specify OS 9 or OS 10, so you may want to search for VW 10 PRefs Quote Link to comment
