bcd Posted May 29, 2017 Share Posted May 29, 2017 (edited) I'm very confused. The attached file shows the same object created from a Marionette Network and then the same network after it's converted to a Marionette Object. Why the difference? I don't need the interior extrude - but it appears mysteriously whenever I convert the wrapper to a M.Object. Any ideas? Thanks Marionette Object vs Network.vwx Edited May 29, 2017 by bcd Quote Link to comment
Kevin McAllister Posted May 29, 2017 Share Posted May 29, 2017 That's super interesting...... I think its related to the hybrid nature of Marionette objects. If you disconnect the extrude node in your Marionette object you get the perimeter as expected but its a screen plane object. The Marionette object transitions to a hybrid object when the Extrude node is executed. It may be WAD or it may be a bug. Kevin Quote Link to comment
bcd Posted May 29, 2017 Author Share Posted May 29, 2017 (edited) interesting is a more benevolent word than I would have chosen for the sentiment - I tried playing around with Set Plane, Pop Back/Front - delete ... but to no avail (yet). I could probably perform booleans on the solids instead or getting the planar objects right first, but that shouldn't be necessary. I think it's either a bug or the bug is that the network omits the center fill in the first place. Edited May 29, 2017 by bcd Quote Link to comment
Marionette Maven Marissa Farrell Posted May 29, 2017 Marionette Maven Share Posted May 29, 2017 not positive that it's a bug at this moment, but the best way to get around this is to extrude the rectangles first and then perform a solid boolean operation on them instead. That will give you the results you want. It's not because of the hybrid nature, though. There may just be a problem when running the Marionette_DisposeObj() function. Our office is closed today, but I'll take a look tomorrow and see if I can learn anything as to why those objects aren't being disposed of properly. Marionette Object vs Network_MFarrell.vwx Quote Link to comment
bcd Posted May 29, 2017 Author Share Posted May 29, 2017 Thanks for the clarity Marissa. I think you're onto something there. I'll give it a go with solids Quote Link to comment
bcd Posted May 31, 2017 Author Share Posted May 31, 2017 Hi Marissa, has there been any response on the DisposeObj() issue? Thanks Quote Link to comment
Marionette Maven Marissa Farrell Posted May 31, 2017 Marionette Maven Share Posted May 31, 2017 I've seen the same problem when outputting a Python script, and there is an active bug reported internally on it. My best assumption is that the call isn't being pushed up and that it's a similar problem for both exporting a script and converting to a Marionette object. I'll report a bug internally shortly, once I can clarify it enough for the engineer. Quote Link to comment
Marionette Maven Marissa Farrell Posted May 31, 2017 Marionette Maven Share Posted May 31, 2017 Bug added: VB-142088 Quote Link to comment
AlanW Posted May 31, 2017 Share Posted May 31, 2017 Does it work if you place a delete on the internal poly node? Quote Link to comment
Marionette Maven Marissa Farrell Posted May 31, 2017 Marionette Maven Share Posted May 31, 2017 Since the Delete node also uses the DisposeObj() function, the same problem exists. Good question though, Alan! Quote Link to comment
