bcd Posted May 28, 2017 Share Posted May 28, 2017 There's probably a solution to this already - but I wonder if it's possible to replace one node with another. This presumably would work only when nodes have the same number/configuration of ports - but I guess the ports could be mapped manually during the replace operation. A simple example is where I'm replacing the a Dim Node with a Passthrough Node. The Dim node currently has 9 wires at the exit port and having to manually rewire the Passthrough node is fraught with danger (& tedious). Simply mapping the Out Port of the Dim node to the Out Port of the Passthrough and selecting Replace Node from a contextual menu would be slick. Quote Link to comment
bcd Posted May 28, 2017 Author Share Posted May 28, 2017 (edited) I am grateful that wires of both nodes will highlight if selected and are individually editable - that's cool. Edited May 28, 2017 by bcd Quote Link to comment
