steebeebo 1 Posted May 27, 2017 I imported a sketchup model into VW. When I look at top / plan view the skup model doesnt render nicely. Any advice on how to go about this? I tried auto hybrid and it didnt work. I also tried converting a copy to polygon but same result. Help appreciated. Thanks! Quote Share this post Link to post
zoomer 688 Posted May 27, 2017 I think there is no chance for pseudo section Top Plan View. You have to live with this. You have some control in Viewports with Hidden Line Mode and playing with crease angle. Same you could achieve with a 3D Top View, but slowness and other disadvantages may make that impractical. Mesh Objects are not a strength of VW or most other CAD Apps. Quote Share this post Link to post
Andy Broomell 691 Posted May 27, 2017 What I would do is: Select the red mesh. Modify<Convert<Convert Copy to Lines. Enter the resulting Group. Using the 2D Polygon Tool in Outer Boundary (Lasso) Mode, draw a lasso around the lines which will give you an outline polygon. Delete everything but the outline (Edit<Invert Selection might be helpful). Make sure the outline is in Screen Plane. Repeat the above process with the chair legs. If it's not already a Symbol, make it into a one so that the 2D components (screen plane) display in Top/Plan, and the 3D meshes appear in all other views. This is a hybrid symbol. You can further work on the 2D display manually by editing the 2D component. 3 Quote Share this post Link to post
zoomer 688 Posted May 27, 2017 Oh, totally forgot about the suitable end result > Symbol = Hybrid with extra 2D appearance. Andy had the correct answer Will work well in Top Plan View. Quote Share this post Link to post
steebeebo 1 Posted May 27, 2017 Thanks Andy. In the image attached I layered multiple viewports and had them on different render styles. 1. floor plan viewport with chair turned off 2 viewport with just the chair (for the chair the top is hidden line render with smoothing angle and open gl for the bottom. ) long process and can cause coordination problems? Quote Share this post Link to post
