SergeyKoltsov Posted May 21, 2017 Share Posted May 21, 2017 Hello everybody. I have a question. How to make a 3D object (symbol) in which I can select options to show or hide properties per component. For example, as it is done in "Stage Deck" where in the settings section in the "structure" section you can select the parameters: - Legs-basic - Legs-Braced - etc. I have my own object in which I want to make the same pop-up menu with a selection of different display options. Thank you. Quote Link to comment
Pat Stanford Posted May 22, 2017 Share Posted May 22, 2017 You need to make a Plugin Object to have that kind of control. The simplest way to make a plugin is to use Marionette, the graphical scripting language. Check the Marionette and Resource Share - Marionette forums for some basic information and a starting place. Ask again if you have more questions. Quote Link to comment
SergeyKoltsov Posted May 22, 2017 Author Share Posted May 22, 2017 2 hours ago, Pat Stanford said: You need to make a Plugin Object to have that kind of control. The simplest way to make a plugin is to use Marionette, the graphical scripting language. Check the Marionette and Resource Share - Marionette forums for some basic information and a starting place. Ask again if you have more questions. I need to create a 3D object using Marionette or can I add display options for objects already created manually? Quote Link to comment
Pat Stanford Posted May 22, 2017 Share Posted May 22, 2017 There is no way I know of to take a manually produced object and add parameters to it. You would need to create all of the objects in the Marionette object to be able to assign them popups or allow data to be entered from the Object Info Palette (OIP) Quote Link to comment
