Beth Globe Posted May 21, 2017 Share Posted May 21, 2017 I am trying the wall framer for the first time. I can get the diagrams up, but the system is not placing studs in the corners. I am trying to do a simple rectangular garage. I also can't figure out how to create the vertical blocking. Can some one please let me know where I specify these items in the system or are these adjustments I need to make manually? Thanks Quote Link to comment
Guest Wes Gardner Posted May 22, 2017 Share Posted May 22, 2017 (edited) Hi Beth, If the framer does not place studs where you'd like them in the corners, you can simply 1) move the ones it DOES create into the proper location 2) duplicate a stud and place IT where you need it to build your corners as you'd like. (Sorry, forgot to "check" double top plate so the framer only created a single plate). I've attached a simple framed model as well as the set-up that created it... Wes Edited May 22, 2017 by Wes Gardner Quote Link to comment
