domer1322 Posted May 17, 2017 Share Posted May 17, 2017 I drew a site in 3D, and recently added a "shell" building as shown in the attachment. There are no interior walls, only the exterior walls and a roof. After adding the walls, I suddenly noticed the screen redraw of the walls in top/plan view are unusually long ... about 3 seconds per wall, or about 30 seconds for the whole thing every time I scroll or zoom in/out. I'm not used to any redraw delay for top/plan view, so I figure something must be wrong. Any suggestions as to what is wrong or could cause it ? I did not use "stories" for the walls, I just duplicated and moved them up for each floor. There are no interior walls, slabs, or any other symbols. I've had much larger file size drawings without this issue (size = 95 Meg) so I'm puzzled. When using RW or OpenGL everything renders as fast as normal. Any thoughts ? Quote Link to comment
Itchy Posted May 17, 2017 Share Posted May 17, 2017 I wonder if it could be related to this issue I'm having where you need to zoom or pan to see any changes. As zoomer pointed out try changing the Navigational graphics setting and see if that helps. I think it may be related to the recent SP3 update as that's when I first started noticing issues. Quote Link to comment
Christiaan Posted May 17, 2017 Share Posted May 17, 2017 Could there be an overly detailed Hatch or Tile in your Wall Style? 1 Quote Link to comment
domer1322 Posted May 17, 2017 Author Share Posted May 17, 2017 Bingo ! Christiaan - you got it right. First I changed the Navigational Graphics from being checked to being unchecked. It had no affect (maybe made it worse). Then I took the VW default wall style for brick veneer with 6" stud cavity insulation and removed all the component hatches (except brick veneer) as Christiaan suggested. Now it scrolls and zooms fast. Case solved ... thanks a lot Christiaan. However, I am disappointed that using the standard VW-provided wall style caused this to begin with. For this job, removing the hatches doesn't matter ... but I envision sometimes where that would be a problem. Quote Link to comment
Christiaan Posted May 18, 2017 Share Posted May 18, 2017 (edited) Glad it solved your problem, but surprised it was a default resource. Can you upload the problem wall style? I'll file it as a bug. Nice model by the way P.S. these kinds of questions should go in the trouble shooting forum. Edited May 18, 2017 by Christiaan Quote Link to comment
