SebastienB
Trouble multi-line field in a plugin obect since VW2017
Hello Everybody,
I have a problem since installation of VectorWorks 2017.
I created a plugin object with text parameters.
When I typed, for example, "Line 1\r Line 2" in a text field in Object Info, the result was:
Line 1
Line 2
It was perfect.
Since I have installed the release 2017, the result is:
Line 1\r Line 2
--> the \r don't works anymore
How can I do?
Thanks
Hi Sebastien,
I guess  VW 17 does not respect  escape sequences because it can have bad side effects.
If you provide a win path for example
folder\ronald  >>
folder
onald
You can print the raw string with the command:
s = StringFromTheField
print (repr (s))
If the result contains  '\\r' instead of '\r' the escape sequence was disabled.
Just replace it with '\r' to make it work again.
s = 'A\\rB'
s = s.replace ('\\r', '\r')
regards
Edited by Patrick Winkler
Prior, Vectorworks wasn't sending escaped strings to the scripting engine.  While this was nice for line breaks, having a text field with, say, an apostrophe could break a script.
-Josh
