Itchy
Drawing changes not visible unitl change of zoom
Thought I would copy in a discussion happening on the chat list that some users are experiencing an issue which seems to be related to SP3.
Pretty much you need to zoom to refresh the screen, so if you join a wall you will not see the change until the page is zoomed or panned. Same situation with most other tools as well.
The problem seems to be both on Windows and Mac and looks like it is happening on file imported from a previous version and new files created in VW2017.
I even built a new PC to try fix it but looks like it is a SP3 issue...
Any suggestion, ability to downgrade to SP2, a quick hotfix to SP3 to fix this?
4 answers to this question
VW Preferences > Display > Navigation Graphics :
set lower than "best performance"
should help.
should help.
Thanks, I'm at the home office today (SP2) so will check and see if changing that setting at the office (SP3) tomorrow makes any difference, however that is a setting that I have never had to change, and if SP3 breaks something we shouldn't be required to downgrade our settings to get it to work like it use to.
I thought it was worse with SP2.
With SP3 I normally use "Best Performance" all the time until it
peeves at a particular point.
Ah I never experienced issues that I can recall on SP2, most my issues began after upgrading to SP3
