Kazemester
Selecting objects with selected objects (for GIS selection)
3 posts in this topic
Dear fellow VW users,
is there any way to select polygons or lines with selected polygons or lines? I mean for example if i have 10 squares in a line next to each other and i have another polygon all above them i want to select the squares only by clicking on the top drawn polygon. Is there any way to do this without selecting all of them?
I want to use VW for some GIS work...making buffer "zones" (polygons) and with these i want to select other polygons (sometimes couple thousand)...it would be another good thing to make a filter such as "this polygon touches the other or intersect or fully contain others..." Similar to ArcGIS or qGIS functions.
Any idea? Or plug-in?
Thanks for the ideas and help!
Zoltan
0
Share on other sites
That's a great question.
Tools > Custom Selection… will get you part of the way there.
Give the area polyline or polygon a name.  Then run Tools>Custom Selection and use the criterion Location = [name of polygon].  That will get you everything that is entirely within the location poly, but not objects that are only partially contained.
But there must be a way.
1
Custom selection is not good when i want to select polys touched by one poly...because they have different names (given by a shape file and database) and usually there are couple thousand that i want to select this way.
0
