Pelle Herfst
VW 2017 SP 3 mac spotlight
Hello,
I have a mayor problem which I just discovered in the Spotlight module.
When I select a random lighting instrument and select "Edit" and perform a random edit, VW crashes immediately.
This happens on all the Mac's we use VW on.
Also we discovered an issue with Inserting Lighting Positions, this feature is not working properly anymore.
I would appreciate a quick reaction on these issues !!
Pelle Herfst
Lighting Designer
Westerdoksdijk  679
NL 1013 BX Amsterdam
The Netherlands-EEC
T: +31 20 62 06 212
M: +31 6 53 15 18 77
E: pelle@rapenburgplaza.nl
W: www.rapenburgplaza.com
Take a look through the tread above. It contains the answer you are looking for. I had the same issue and this solved it.
good luck
Hi Markdd,
I threw away the RunTimeCache as described in the thread but it did not solve the crashing problem for me unfortunately.
I have just come across this when trying to put shutters in on lights, no sign of the RuntimeCache in my plug-in folder
1 hour ago, Pelle Herfst said:
Hi Markdd,
If you already updated to the latest service pack (sp3) and removing the runtimecache did not resolve your issue, make sure to get in touch with support directly and they can get you sorted out. tech@vectorworks.net
Any update to this issue? Same problem here when trying to add, edit or select a lighting instrument. Trashing the RuntimeCache did not help.
Contacting tech@vectorworks.net directly is your next step in that case.
I have just had this issue resolved with the help of tech support. It was indeed the run time cache folder did you make sure to empty trash after deleting the file?
