holly lb Posted May 10, 2017 Share Posted May 10, 2017 I've been following the tutorials for Vectorworks Spotlight (2016 version) and when you get to the section where you have to convert your platform into a stage, the toolbar that you are directed to use is on the old version is no longer there on V17. Where can I find it? Quote Link to comment
Guest Beckstorm Posted May 11, 2017 Share Posted May 11, 2017 Holly, The workflow did not change in 2017. Do you not see the "Event Design" menu or the menu command for "Create Stage"? If you don't see the "Event Design" make sure you're in the spotlight workspace if you're missing the command you can add it via the workspace editor. Hope this helps. Quote Link to comment
holly lb Posted May 11, 2017 Author Share Posted May 11, 2017 Thank you so much! Quote Link to comment
