marshigh
exporting VWA model for use in sketchup and cinema4D
2 minutes ago, marshigh said:
I don't know what this means?
Sent to Cinema creates a temporary Export File deeply hidden in your Computers cache folders.
Beside it does the same as the Export.
This is not adequate in your situation as you need the C4D file for sending.
Edited by zoomer
Typically I would send a series of simple 3D shapes with known sizes to the illustrator and get him to check everything is there, everything is sized correctly and has the correct materials/colours etc. Once you have this then work from there.
1 minute ago, barkest said:
Look at the image you just sent and you will see it as an option on the menu File > Send to Cinema 4D
Oh...I didn't see that option.
But I tried it...I (don't have ) a cinema 4D application to send it to....The illustrator does.
So am I out of luck? I'm exporting with the correct setting apparently, but it's yielding zero bytes?
Put a 1m x 1m x 1m cube in VWA and put a texture on it. Export to C4D and then put the file onto here and I will open it up for you (needs to be in the next 30 mins)
cube.c4d
FYI: I just turned off the other layers and kept only the 2nd floor "on"...and the export yielded a file that was 881KB.
What does this mean?
Looks fine. I needed the texture as well CVS209 but no matter it works ok
so exporting each floor individually did yield some results. but since I don't know anything about SKUP or CIN4D....I don't know if this is useful or not.
The export works fine (as expected). As for what you should send then its up to you to discuss with the illustrator and work out what is best for both of you. Personally I would take the whole project in one hit but as I say you need to discuss this.
The last export image is attached and is what I see in C4D - No issues at all
Wow, such a nice Cube ;)
Just kidding ...
Everything fine so far ...
RE: "personally I would take the whole project in one hit".... we are seeing that it's working now...great...and THANKS!!!...but how do I give the whole thing to him. The unified "model" saved view with all the layers turned on is what was giving me zero bytes.
it worked!! the only thing I changed was having the foundation/basement as the active layer!!!!
If that helps you can Export each Layer separately.
Shouldn't make any difference but hey if it works then go with it.
Can the Su option
Yes, either a bug in export module
or maybe just a corrupt Plugin Object that may cause some trouble elsewhere in the future too.
But I will try if changing Active Layer would help for my 0 MB FBX export too :)
regarding corrupt plugin object....that's why I completely stripped the project...to try to rule that out. Out of curiosity (and FYI), I went back to the "unstripped" file, made the foundation the active layer and tried to re-export....nothing again. So perhaps there is a problem "bug" hiding somewhere. Thanks to both of you for your help!!!!....and patience!!
You're welcome.
Problems from others are quite interesting as these could happen to us at one point too :)
No, it's not that easy.
I tried to switch parts off before export to find the problematic part in my file.
Unfortunately all 3 parts exported fine.
When I tried again with all Layers needed I got my zero size FBX again xD
Edited by zoomer
I tried to switch parts of before export to find the problematic part in my file.
I'm glad you posted about this...I was wondering.
After all that...the illustrator says he'd rather have the dwg (saved selected view) export. These were my settings for that scenario. Would you make any changes to settings from what I have here?
On 5/3/2017 at 10:52 AM, zoomer said:
You could try to avoid that "point" in the export file name or any other special character.
I would also try to  duplicate the VW File with a simple name as that name may finally appear as Group Folder name in C4D.
were you referring to the "." between VMT-2139 and V4?
