Markvl Posted May 1, 2017 Share Posted May 1, 2017 Lets have some helpful, useful fun here. Submit a Tool and its use in situations where it wasn't originally designed for. For example I use the Roof Face Tool to create my residential garage slabs so that I can easily provide a slope and still have the forward and rear edges vertical (using the "vertical miter" option). Like a slab I can have components such as poured concrete, a vapour barrier and a gravel base. Lets see what you've got. I'm sure we have all had situation where you wondered "how can I do that?" as there is no tool specifically named or designed for your situation. Quote Link to comment
Rossford Posted May 2, 2017 Share Posted May 2, 2017 If they don't introduce a drainage tool in Landmark this year, I might adapt the irrigation tool to drainage design. Quote Link to comment
Itchy Posted May 4, 2017 Share Posted May 4, 2017 As an alternative to Vectorworks I use "Insert other CAD programs here" - j/k I use the framing member for a lot of things; glass balustrades, gutters, flashings I use the roof face tool to create ridge and valleys flashings for the elevations. I just used the Feature control frame tool to create a wall key - this tool can have up to 5 boxes that you can control through the OIP. Quote Link to comment
Matt Overton Posted May 4, 2017 Share Posted May 4, 2017 On 02/05/2017 at 1:04 AM, Markvl said: Lets have some helpful, useful fun here. Submit a Tool and its use in situations where it wasn't originally designed for. For example I use the Roof Face Tool to create my residential garage slabs so that I can easily provide a slope and still have the forward and rear edges vertical (using the "vertical miter" option). Like a slab I can have components such as poured concrete, a vapour barrier and a gravel base. Lets see what you've got. I'm sure we have all had situation where you wondered "how can I do that?" as there is no tool specifically named or designed for your situation. I'd say maybe 10% of the roof faces in my models are slopy slabs. Sometimes more like 50%. It would almost be fair say I use more roofs as slabs than slabs as slabs. Quote Link to comment
zoomer Posted May 4, 2017 Share Posted May 4, 2017 (edited) I use multiple 2D Elements in a single Extrude all the time. Like a bunch of Rectangles for my Columns. Once extruded I can adapt their height at one time. And for Profile Changes I can go in and keep my 2D edit ability of multiple objects at one time. Plus the option to choose the origin for size changes. All of which isn't possible with VW 3D Tools or Solids. Also I misuse Solid Additions to just gGroup Objects and force them to export as one single Mesh Item into other 3D Mesh Apps. Edited May 4, 2017 by zoomer Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 4, 2017 Vectorworks, Inc Employee Share Posted May 4, 2017 I make extensive use of the Extract tool, specifically in Extract Surface mode. This tool allows me to grab one or more individual faces of an object, give it a slight nudge to offset it from the face of the original, and then apply whatever texture I like to the extracted face to cover the up the untextured (or undesirably textured) original. This technique is a frequently used workaround for the current limitations to the texturing abilities within Vectorworks. Quote Link to comment
barkest Posted May 4, 2017 Share Posted May 4, 2017 1 hour ago, JimW said: his technique is a frequently used workaround for the current limitations to the texturing abilities within Vectorworks. So when you say 'current' this means 'only for now' but could change? (have to hold on to any straw I can see blowing around) Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 4, 2017 Vectorworks, Inc Employee Share Posted May 4, 2017 Certainly "Could" change, but I continuously push for "Will" change. No confirmation of anything yet and nothing in the immediate future that I can see, but it's now the top item on my list of crusades. 1 Quote Link to comment
ericjhberg Posted May 4, 2017 Share Posted May 4, 2017 I use the NURBS roadway tool to create complicated site modifier 3d polys with precise vertical gradients along curved paths, swales, and anything curvilinear that requires intricate vertical grades. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 8, 2017 Vectorworks, Inc Employee Share Posted May 8, 2017 Another item I was reminded of in another thread: Saved Views, in another use that wasn't REALLY their intended purpose but one that works very well, can also be used to configure a file as a sort of slideshow/powerpoint even in 3D. @Luis M Ruiz makes great use of this in many of his tutorials. Below you can see this in action around the 13:08 mark:http://www.vectorworks.net/inspiration/industry-webinars/the-art-and-function-of-3d-modeling Quote Link to comment
rowbear97 Posted May 11, 2017 Share Posted May 11, 2017 I use the hardscape tool in Landmark to create soil volumes to quickly do takeoffs. Quote Link to comment
barkest Posted May 12, 2017 Share Posted May 12, 2017 On 08/05/2017 at 4:13 PM, JimW said: http://www.vectorworks.net/inspiration/industry-webinars/the-art-and-function-of-3d-modeling @Luis M Ruiz does a great job with this tutorial Quote Link to comment
