benchemoul Posted January 26, 2004 Share Posted January 26, 2004 G4 dual 867MHZ, 1GB, MacOs 10.2.8, VW 10.5.0 When I try to import DXF/DWG, I get this message: Could not open the OpenDWG Initialization file, "adinit.dat". Please reinstall Vectorworks. I reinstalled but still get the same message. What can I do to correct this problem? Thanks anyone Quote Link to comment
Guest Posted January 26, 2004 Share Posted January 26, 2004 Do you have a non-english version of VW? Quote Link to comment
benchemoul Posted January 27, 2004 Author Share Posted January 27, 2004 Hi Kathy, I bought it in Israel, so I suppose it is non US Quote Link to comment
Guest Posted January 27, 2004 Share Posted January 27, 2004 Is the program in english or another language? If it's not in english, you'll need to contact your local distributor. It sounds like something isn't translated properly. Quote Link to comment
benchemoul Posted February 1, 2004 Author Share Posted February 1, 2004 Katie, sorry for the delay answering. The program is in english with a dongle. ?? Quote Link to comment
Guest Posted February 2, 2004 Share Posted February 2, 2004 Can you import any dxf file? What version is the dxf file you are trying to import? Quote Link to comment
benchemoul Posted February 3, 2004 Author Share Posted February 3, 2004 The file is .dwg. The message I get is: OpenDWG Library Error 182 Quote Link to comment
Guest Posted February 3, 2004 Share Posted February 3, 2004 What version dwg is the file? If it's an AC 2004 file, you won't be able to import it. Quote Link to comment
benchemoul Posted February 3, 2004 Author Share Posted February 3, 2004 Thank you. I'll check with the sender Quote Link to comment
