Christian Fekete Posted April 28, 2017 Share Posted April 28, 2017 Is it possible to subtract one solid from multiple solids at the same time? Quote Link to comment
0 Andy Broomell Posted April 28, 2017 Share Posted April 28, 2017 Unfortunately not. The two best approaches I've found are: First select the various solids you want to keep and do Add Solids, then take the remaining solid and Subtract it from the single Solid Addition. The advantage being time, the disadvantage being you're left with a single object. [Note that the original solids don't have to actually be touching to create a Solid Addition]. Subtract Solids one at a time, but make sure to check "Retain subtracting objects" so it can easily be reused on the next object. 1 Quote Link to comment
0 Christian Fekete Posted June 19, 2017 Author Share Posted June 19, 2017 Thank you Quote Link to comment
Christian Fekete
2 answers to this question
