Christian Fekete Posted April 28, 2017 Share Posted April 28, 2017 Can you please allow repetitive push pull with previous amount so as not to have to pull for the same amount multiple times? thx Quote Link to comment
0 zoomer Posted April 28, 2017 Share Posted April 28, 2017 Asked for that in 2014 too Quote Link to comment
0 Markvl Posted May 1, 2017 Share Posted May 1, 2017 Would you give/show an example of what you're referring to @Christian Fekete? I'm not sure I understand what this is in relation to the tool. Quote Link to comment
0 zoomer Posted May 1, 2017 Share Posted May 1, 2017 (edited) The case is that you have to pull faces of MANY objects always by the same amount. In VW you have to input that same amount numerically every time again. In Microstation (each! related) tool had a check box to input a fixed number and lock to this distance. Similar to what you have in VW for a Tool like copy polygon boarders parallel at a certain distance. Also it always remembered the last distance used and provided it as a potential snapping point. That way you can use it without input again if you want or something else if not. Also in Microstation the cursor direction always gives the direction, if values are used negative or positive. So you can still pull faces of one part of your objects out, while pull others in, at that fixed amount. + Some other things like a lock to edit only objects already selected and a few other. Edited May 1, 2017 by zoomer 1 Quote Link to comment
0 Markvl Posted May 1, 2017 Share Posted May 1, 2017 Right. I get ya. Thanks for the clarification @zoomer Quote Link to comment
0 cberg Posted May 1, 2017 Share Posted May 1, 2017 Sketchup has a plugin for this: Multiple Push Pull https://www.youtube.com/watch?v=YCMOcgVKSfI Quote Link to comment
0 zoomer Posted May 2, 2017 Share Posted May 2, 2017 ^ That is exactly what our Extrude Tool does from 2D Shapes. Including the flipped original Faces Quote Link to comment
Christian Fekete
6 answers to this question
