Drake Posted April 28, 2017 Share Posted April 28, 2017 I am trying to use the column took, but every time I try to create one, the are just wire frame and have no surface (see image). When I insert one in a new file, the column appears as I would expect it. Quote Link to comment
Andy Broomell Posted April 28, 2017 Share Posted April 28, 2017 I'd first check that the fill style in the Attributes palette is set to Solid with the object selected. If it is set to None, or if it set to Class Style and the class is set up to have no fill, then 3D objects will appear wireframe. Quote Link to comment
zoomer Posted April 28, 2017 Share Posted April 28, 2017 And Column Tool allows to set extra Classes. Attributes by Class or per Object, I also think that the geometry just has currently no Fill applied but would appear if it had. Quote Link to comment
Drake Posted May 1, 2017 Author Share Posted May 1, 2017 Thanks for trying to help guys. I have attached another screenshot showing the attributes and object info palettes while the object is selected. Maybe you can see some clues here. Quote Link to comment
barkest Posted May 1, 2017 Share Posted May 1, 2017 If you create a column only in a new doc its the same? Maybe attach a copy of the vwx file with the column in it Quote Link to comment
Marionette Maven Marissa Farrell Posted May 1, 2017 Marionette Maven Share Posted May 1, 2017 My best guess is that your 'None' class has its fill attribute set to None and that your columns are being created with those attributes. In the OIP, when you click the 'Get Finishes/Classes', what are the classes listed? If they are set to either 'None' or <Column Class>, in your navigation palette, under the Classes tab, right click on the 'None' class and select 'Edit', what does that window look like? That is how I was able to reproduce what you were seeing. 2 Quote Link to comment
zoomer Posted May 1, 2017 Share Posted May 1, 2017 1 hour ago, Drake said: I have attached another screenshot showing the attributes and object info palettes while the object is selected. I see at first that the OIP column dialog is a nightmare with no visible hierarchy what is most and what is less important and that it is far too long for what such a simple column should be at the end. BTW, the special Class assignment options will come at the lower second part of the long list. That way you can assign all your Columns into an overall Main Column Class while defining special Materials for its individual Components, for better Visibilities Control and Oragniszation. Just like you would for other Architectural Plugin Objects like Walls, Windows, ... Shouldn't the Attribute Palette show "by Class" Attributes when the Ccolumn is selected and the None Class had no Fill but controls the Column ? Quote Link to comment
Drake Posted May 3, 2017 Author Share Posted May 3, 2017 So I sent the file to Tech support and this is how we corrected the problem. Despite the fact that I was trying to use class overrides for the fill, apparently it was still using 'by class' and the 'None' class that I was using had no fill. When I changed the None class to 'solid fill', the column was rendered as a solid! I changed the class to one that had a solid class fill and moved on. Quote Link to comment
SeanH Posted November 18, 2024 Share Posted November 18, 2024 I had the same issue. My fix was to open the style edit settings, go to classes / materials and ensure that the shaft, capital and base component finishes are not set to none. Set them to the class you want. Quote Link to comment
