DePijp
Wall components visible in window and door openings in section and elevation viewports
Hi everyone,
I am working on a project in Vectorworks using the wall component to model a cavity wall. I have created a wall style with a dashed blue line to represent the Vapour Control Layer using the pen style and a component thickness of 1mm. When I insert windows and doors into the cavity wall, the blue line is the only component visible within the window/door opening opening both in section and, to an extent in, elevation. Please refer to images for further explanation.
Any ideas what the issue is or how to fix it?
Many thanks in advance,
Sophie
Edited by DePijp
1 answer to this question
@DePijpWould you not just turn off the class in the elevation. Can you add a sample VW file for us to look at.
