Window Recess Depth Within a Wall
TArchit
If its a custom symbol and not a Window in Wall, then you can edit the 3D component of the symbol, enter Top/Plan view, and then move the symbol so that it rests at the depth in the wall you like. This depth will be relative to the Symbols 0,0,0 origin, not the walls thickness.
For regular Window in Wall objects, there is a "Plan Wall Offset" field that lets you to it automatically by entering a positive or negative offset value depending which direction you want to offset the window in relation to the wall.
