Jim Smith Posted April 24, 2017 Share Posted April 24, 2017 I often have to indicate a cupboard above on a furniture plan. I have to group this as a hybrid 2D dotted line in a class A-Millwork Above and a 3D object that represents a cabinet in an elevation & or a section. I'm not interested in getting into the weeds designing the cupboards, just showing the intent in 2D & 3D. This is a pain as one has to remember to adjust in both classes when a things change. Is there an alternative? Quote Link to comment
AlanW Posted April 24, 2017 Share Posted April 24, 2017 (edited) @Jim SmithHi, You may be already doing it this way but i handle this situation as attached. 3 classes for the Hybrid and saved as a style so anytime i create a hybrid it sets up automatically, then its just a matter of adjusting the heights as needed. High stuff I leave the cut plane set to zero while anthing i need to look down on i set it at a height above the height of the top relative to the design layer RL. PS After you first set up the Hybrid click this bottom save as (attached) and all will set up automatically for the hybrid. Cupds.vwx Edited April 24, 2017 by Alan Woodwell Quote Link to comment
Jim Smith Posted April 24, 2017 Author Share Posted April 24, 2017 Somewhat Alan, But what would be a real improvement would be to be able to avoid having to have a hybrid in many instances. Take a Roof overhang, if one could just turn the roof layer on but DASHED this would be a huge time saver. Quote Link to comment
AlanW Posted April 25, 2017 Share Posted April 25, 2017 I tend to use all 3D as much as possible and not have to draw any 2d lines over. See roof and floor plan and in the viewports i tend control everything. HTH Plan.vwx Quote Link to comment
Jim Smith Posted April 25, 2017 Author Share Posted April 25, 2017 I wouldn't want to show the ridges & valleys of on a floor plan. Conventionally one would show a dashed line to represent the line of the roof above at the roof's edge. Your illustration is good as it makes me realize there should be a Class to a Roof object to allow one to do this. Quote Link to comment
