Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Sign in to follow this
TArchit
Custom Window Arrangement
I need to create the attached window arrangement, essentially two standard windows with a large mullion cap in between and a bulkhead or inset lintel above, as a symbol to be inserted within walls.
Is this possible and if so how would I achieve it?
Edited by TArchit
Share this post
Link to post
Yes, when creating a Symbol from your custom Window geometry you can
activate the Wall Insertion Option.
In this case you will even have another "Layer" in your Symbol to define a
special Volume for the Wall Cut.
In many cases you can even mainly use a real Window + some additional
custom geometry in your Symbol to keep some parametric control.
Share this post
Link to post
