Export Site Model IFC ?? Crashing, freezing...
nca777
  • 2 weeks later...
  • 1 year later...
@nca777
I did a little more investigating and while I wasn't able to export the site model as an IFC I did come across a way to get a fairly clean 3D Polygon version. When exporting you site model make sure that you have changed the site model 3D visualization to contours no mesh. Once you have done that you export as a 3DS file. Bring that back into Vectorworks and you will then be able to select the triangular 3D polygons and deleting them leaving behind only the contours. Hope this helps.
  • 2 weeks later...
  • 3 weeks later...
  • 2 weeks later...
  • 3 weeks later...
