J. Wallace
View port not rendering as expected
I"m having some strange behavior from a series of VP today and would appreciate any help or ideas one may have. I have three viewports of the same view rendered in different settings, Open GL, Fast renderworks and Final renderworks. You'll see that a driveway is visible in Open GL but the fill  in both fast and final RW does not show up. I rebooted to see if that helped but no...as a side note I had some issues working on the model yesterday which seemed to fix itself. Also a recent video card upgrade. Thanks for you thoughts.
PS you'll also notice both the fast and final RW viewports have a red dotted outline even after updating.
Edited by J. Wallace
Added PS
If you copy that driveway object out and paste it into a new blank file, does it render then in OpenGL as well as Renderworks modes or no? What type of object is is, a slab?
Hi Jim
If I copy and paste this to a template or blank file I get the same result, it will render in OpenGL but not either of the RW modes.  I currently working on a 'Work around' creating a new hardscape element which seems to be fine.
If you could, send me the file with just that object and I can take a look. If it's a hardscape there are sometimes other subsettings that can mess with rendering.
I think it's something with the hardscape itself, the same texture applied to a simple extrude works fine in his test file. Going to see if this is an already filed issue.
