the set working plane tool has only two methods: you can align it to a surface or you can use three points to define it.
In many cases, I want to look in the direction of a certain line in 3d space (the edge of some object or just a segment of a 3d poly), especially to rotate objects around a line, using the line as an axis. So I would have to set the working plane perpendicualar to the axis.
What is the best way to achieve this? Or are there other ways to rotate objects around existing linear objects in 3d?
MarcU
Hi
Thanks for any help.
Markus
4 answers to this question
