Viper x Posted December 8, 2002 Share Posted December 8, 2002 Thanks in advance for your help Problem I. Warning _ 770 _ 771 - Polygon handle is not valid Warning _0 _ 13- Object passed to routine is not the proper type Error _0 _ 79 - You must allocate the dynarray before using it I am using the place plants funtion and this comes up particularly when trying to use the " along polygon edges " command. What am I doing wrong please ? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 8, 2002 Vectorworks, Inc Employee Share Posted December 8, 2002 You will get this message when you try to draw a two-point polygon, which is "not legal". Try drawing a three point poly (all in a straight line) instead. Note: this is a bug fixed in an upcoming release. Quote Link to comment
Viper x Posted December 9, 2002 Author Share Posted December 9, 2002 It worked ! fantastic Robert, it is a relief to get things working and progressing. Thanks Viper x You will here a lot from me I think until I get a handle on this software. Quote Link to comment
Thom Posted December 9, 2002 Share Posted December 9, 2002 Robert I am getting the same error even when using the "3 point poly". Usually the symbols will appear after clicking through 4 script error messages, then it take 4 more error messages for the messages go away. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 10, 2002 Vectorworks, Inc Employee Share Posted December 10, 2002 Thom, this is normal behavior. It takes a couple of iterations to "clear" the bad data introduced in a hidden record when the old error appears. Quote Link to comment
