jimbo
Constraints
Hi,
I don't know what I have done inadvertantly, but I must have used a keyboard combination that has changed something.
As a result I cannot :
shift select nor marquee select
press shift to constrain a line direction nor shift to constrain a line or object alteration.
Hope you can help.
Regards
jimbo
VW 10.5
Mac 10.2.8 G4 Ti
Ram 512 [Confused]
It sounds the shift bug.
OS 10 has a problem with Shift, Cmd, and Apple keys. They simply stop working. When this happens, a simple restart of the computer works, just as Kevin mentioned.
I see you are using 10.2.8 - most of the function keys problems mentioned above were mostly resolved by this version.
If you haven't done so in a while, run disk utility in the utility folder. Make sure you run verify and fix disk permissions. The problem should happen alot less often once run this.
[ 01-16-2004, 10:29 AM: Message edited by: Katie ]
