AJTotal
Render Questions for Spotlight
Hey VW Friends,
working on rending some 3d shots of a design we are working on for a project and i'm not sure what i'm doing wrong. any time i try fast or final render works i just get a solid colour Crop. but yet in open GL i can see my full shot, what is also interesting is in Open GL not all my lights turn on, yet they are all duplicated from the first one thats turned on. for my final render work i figured it could also be my Ambient lighting was too dark at 12% so i upped it to 75% and all i got was a more Brown Screen instead of black, i attached that screenshot too.
I guess i'm trying to figure out the best render settings for presenting my projects that all the lights are on and i have a nice dark ambient lighting,
Thanks in advanced VW Friends.
Andrew
Total Events
if you select your viewport and open up the visualisation palette you can see which lights are on for that particular viewport
OpenGL has a limit for the numbers of lights it can use.
I think it was max 8 (?) lights.
You might be "inside" something as you render.  Try shifting your view a bit to see if that helps.
Ambient lighting is sort of like turning the brightness up on your screen. I don't recommend it for a good look as it flattens out things. If you feel you need to, turning on ambient occlusion will help bring back some contrast.
Hey barkest, I checked to confirm and all the lights are on,
Hey Grant, i also thought i was inside something, but in Open GL vs final technically my walls or camera position don't move, and my 2 screen shots the only thing i changed was open GL to Final or Fast Render.
