annapla Posted April 3, 2017 Share Posted April 3, 2017 Hi there, please could someone help me. I'm tracing over a plan and want the exterior walls to be 6500 mm. wall style brick. and they just don't show up as soon as i go into 3d. is there anything in the walls settings that I can change to make them visible? thanks in advance!! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 3, 2017 Vectorworks, Inc Employee Share Posted April 3, 2017 Do they have a fill of Solid in the Attributes palette? If they're set to a fill of None they won't be visible other than in TopPlan or Wireframe. Quote Link to comment
annapla Posted April 4, 2017 Author Share Posted April 4, 2017 thanks for the quick help!! they are on 'none' but thats because i chose a wall style within from the resource browser. if I make them solid than they don't show the cement layers and all in the top plan view right? they will just look like extruded polygons. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 4, 2017 Vectorworks, Inc Employee Share Posted April 4, 2017 In Top/Plan view you should see the Wall styles 2D component fills, in Top it would look like an extrude but with the textures for each component for the fill instead. If you leave it with a fill of None you wont see anything in 3D. Quote Link to comment
AlanW Posted April 4, 2017 Share Posted April 4, 2017 (edited) Look at one of my older videos on texturing walls and roofs May assist. Edited April 4, 2017 by Alan Woodwell 1 Quote Link to comment
annapla Posted April 4, 2017 Author Share Posted April 4, 2017 Thank you alan and jim! so the video was really helpful. I have done exactly what you did. drawn a shape and then created walls. the problem is that they won't extrude. I can't even set the attributes on 'solid'. maybe the screen shot helps. I just want to set the wall on a certain height and have a brick texture. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 4, 2017 Vectorworks, Inc Employee Share Posted April 4, 2017 Those walls have no Height assigned to them. In the Object Info Palette, change it from 0 to a desired single floor height. Or, change the Top Bound to be bound to a level higher than the bottom of the walls. Quote Link to comment
annapla Posted April 5, 2017 Author Share Posted April 5, 2017 yea that was the problem though. in the screen shot you can see that if I change it to the desired 6500 mm then it still doesn't show. I'm really lost here. I have started a new file so many times as well. usually I just draw a wall, type in the height in the object info palette and done. but this time it just won't extrude no matter what. is there a way to maybe reset all settings of vw? or what is the best way to get on with the file? Quote Link to comment
Tom Klaber Posted April 5, 2017 Share Posted April 5, 2017 If you send me the file, I can take a quick look. 1 Quote Link to comment
Pat Stanford Posted April 5, 2017 Share Posted April 5, 2017 If you go to the Organization Palette and Edit the Layer the walls are on, what is the settings for the Layer Wall Height? If that is set to zero then the walls will not be very tall. Also, you are using a Styled Wall. Check the settings of the wall style and see if they are bound to something other than what you expect. Quote Link to comment
ilimatiare Posted April 15, 2020 Share Posted April 15, 2020 Did you Ever get this resolved? I am having the same issue... Quote Link to comment
