symo 7 Posted March 28, 2017 Hi All Having an issue when VW 2017 behaves very strangely when inserting lighting instruments when a plan is rotated (i.e a saved view). Here are the issues: The default position is zero degrees in the unrotated orientation - so you need to rotate every fixture to insert it at zero degrees in the current view. Can this be overridden? When using the Align/Distribute Objects function to evenly space and align the instruments, i get unexpected results When I select the instrument with the plan rotated, I see the the outline of the the symbol in a zero degree orientation Let me know if im missing something obvious of if there is a work-around Cheers Quote Share this post Link to post
michaelk 466 Posted March 29, 2017 I've seen the same thing w/ rotated plan. @JimW is this a bug? mk Quote Share this post Link to post
PVA - Jim 2,382 Posted March 29, 2017 Hrmm, I actually see this bug as submitted in 2017 SP0 marked as fixed in 2017 SP3, let me double check and confirm it on my end. Quote Share this post Link to post
michaelk 466 Posted March 29, 2017 I'm still seeing it in SP3 with instruments in Spotlight. I haven't checked the align/distribute thing recently in an Architect workspace, but that was still happening a few months ago. mk Quote Share this post Link to post
PVA - Jim 2,382 Posted March 29, 2017 Apologies, I misread the bug I was looking at, it was regarding screen redraw not updating until you zoomed, which seems to have been fixed. 1) At the moment I know of no way to get the Instrument insertion tool to respect "up" as the new 0deg rotation when inserting, it's always aligned along the doucment rotation, I'll see if theres a way round this or file a wishlist item. 2) Align/Distribute when in Rotated Plan doesn't seem to be following any logic that I can see, it doesnt align them in relation to the original rotation nor the custom one, and distribute seems to only distribute some of the objects but not all. Filed as a bug VB-136953 3) I can't replicate this on Mac or Windows, do you see it even in a new document with a newly inserted instrument when using Rotated Plan? Quote Share this post Link to post
michaelk 466 Posted March 29, 2017 2 minutes ago, JimW said: 2) Align/Distribute when in Rotated Plan doesn't seem to be following any logic that I can see, 2 minutes ago, JimW said: 3) I can't replicate this on Mac or Windows, do you see it even in a new document with a newly inserted instrument when using Rotated Plan? I'm not seeing this one. Just 1 and 2. mk Quote Share this post Link to post
Rob Books 189 Posted April 4, 2017 I just put in bugs for two of these issues. 2) if you use the align/distribute keyboard shortcut (Ctrl =) and use align distribute in a rotated plan it will give odd results, everythign is on a 45 degree angle. if you use the Spotlight Align Distribute tool, it works fine. 3) This has to do with Rectangles in the 2D portion of the symbol. if you adjust view and then go back, it looks fixed but will reappear if you move the symbol. and it only occurs when the symbol is place in a cardinal direction (0, 90, 180, 270) on a 90 degree rotated plan. Quote Share this post Link to post
Charlie Winter 69 Posted April 5, 2017 (edited) On 3/29/2017 at 11:48 AM, JimW said: Apologies, I misread the bug I was looking at, it was regarding screen redraw not updating until you zoomed, which seems to have been fixed. I am experiencing this screen redraw bug, with Spotlight Instrument Objects, which you say has been addressed. The attached image displays 3 MAC Aura, the middle having been recently inserted, but not showing up. A quick tap on my 3D Connexion mouse triggers a zoom that immediately refreshes. This is however not ideal. Please advise. Vectorworks 2017 SP3 (Build 356720) OSX 10.12.4 Sierra Edited April 5, 2017 by cwinterLD No signature with details. Quote Share this post Link to post
Rob Books 189 Posted April 5, 2017 what is your navigation Graphics set to? try it at Good performance and compatibility Quote Share this post Link to post
Charlie Winter 69 Posted April 5, 2017 My navigation graphics was set to Best Performance. On your advice, I set it 'Good Performance and Compatibility' then closed, and restarted Vectorworks. Repeating the action shown in the screenshot of my previous post, the fixture still does not appear without a zoom. I am using the 'Move by Points Tool' with object retention mode enabled, to copy the left fixture to the middle. Quote Share this post Link to post
Rob Books 189 Posted April 6, 2017 I think this might be a separate bug related to the copy of the already inserted fixture. @JimWwas there a bug on that? Rob. Quote Share this post Link to post
