SCParker
Editing 3D truss item, can't select the blue lined simplified box shape
Greetings,
I'm creating a few versions of the Tomcat TC1212-AHB symbol at different angles. I duplicated the symbol and edited to make a 45° version. There is a simplified shape that I cannot seem to select. In Edit 3D mode, the outline of the box is in blue. The second screen shot is what I have at the moment. How do I select the blue line shape to edit?
Thanks, Scott
2017-03-27_12-23-16.jpeg.1ff5d97743af666b15e5125ad5385672.jpeg2017-03-27_12-17-54.jpeg.17b58aad91be5f446dc20d0181f99e37.jpeg
2 answers to this question
that geometry is in the Rigging-Truss-Simplified Class.  make sure you have that class active and you should be able to move it and adjust it.  I am guessing you have your classes set to show others or similar.  you can also set your class options to Show/Snap/Modify Others, and then you can grab all geometry and move at the same time.
Rob.
Thanks Rob.
Hmmm. I had all classes on, etc.
I had to turn off and on the Simplified class to get it to show. It's working now. Go figure.
Thanks, Scott
