Tom Klaber
Document Switching Broken in Windows (URGENT)
Switching between documents is now suddenly broken after a Windows update.  If you go to Window - and select a different document - the view will change - but the navigation will not update and nothing will be selectable, and you will not be able to return to your old document.  The mouse still works, you can select tools - but you get very strange cursor when you do.  The only fix I have found is to close the document you are stuck on.  VW itself does not need to close.  If you close the document - the other one that you were trying to get back to seems fine.
It goes without saying that this is a huge problem.
@JimW - Sorry to tag you on this - but I wanted to bring it your attention right away.
19 answers to this question
Updating my Win10 machine now.
(Side note: Always feel free to tag me, that's what it's there for!)
Installed all available updates for Windows 10 and I am unable to replicate this. Does the same thing happen for you after a reboot and opening two new blank files, putting a few objects in both and then trying to switch between them?
Now I am unable to replicate.
@JimWSorry for the wolf.  I thought I had tried everything (closing / rebooting) before posting - I guess this one needed 2 reboots.
@Tom KlaberTom are you talking about switching between VW documents? If so I use ctl + tab to swap between drawings.
Yeah - I never got in the habit of using that.  Mainly because I want to go straight to the file rather than cycle through.
I would have like to test that on the bugginess - but something tells me that would not have helped.
Is Windows getting tabs?  I very much liked the tabs.
@Tom KlaberUse alt +tab to bring up all on screen, hold the alt key then youu can pick the one or windows key + tab to scropp through on screen.
HTH
Edited by Alan Woodwell
Thats cool - though it does not let me select the Vectors Documents - did does not seem to recognize the multiple files.
Good Morning All,
We have the same issue I our office, it is completely random and hard to replicate.
It has happened on a few computers (4/5 out of 12), if we tab between VW windows we can see the new documents but all the commands are happening in the we have changed from.
It can happen if we have two docs open or four or five, I can not seem to replicate why it happens. I have even closed and reopened the documents I had open in the same order and it work the second time.
The only solution we can find at the moment is to shut VW down and restart
Unlike Tom we haven't updated any of our systems apart from installing VW2017
We are using Window 7 Professional.
Any ideas?
Thanks
Yessir.
On 3/17/2017 at 7:11 AM, VW-PAD-Bristol-2014 said:
Good Morning All,
Any ideas?
Thanks
 It very well could have been that the windows update was just a coincidence.
I have not had the time to dissect it, but I am not thinking that it might have to do with a very heavy file, and once I triggered that error - the error persisted even though that file was no longer open, which is why the restart the second time fixed it but not the first - but because on the first reboot I reopened the heavy file first.
That was a lot of words - but glad to hear I am not crazy.
@Tom Klaberif it helps when restarting try this, turn computer off unplug power cable, push start button to drain the last bit of power from the machine then plug it in again and restart. Sometime the power holds memory and this clears all .hth
