Bruce Kieffer Posted December 27, 2003 Share Posted December 27, 2003 Since update to VW 10.5.1, my PowerBook G3 Bronze will not auto sleep after 10 minutes of inactivity as I have set in my energy saver. This only happens when VW is running. If I quit VW the computer will sleep as expected. I tried turning off the VW auto save, but that made no difference. Any suggestions to fix this would be appreciated. Quote Link to comment
Speedy Gonzales Posted December 27, 2003 Share Posted December 27, 2003 This may be a coincidink, but I am experiencing a similar situation on my new PowerBook G4 running Panther 10.3.2. When I close the lid to sleep, and then lift the PB and put it into a vertical position (as if to slip into a case), it wakes back up. The similarity is that I had recently installed VWA 10.5.1b first, then upgraded to Panther, sent in my PB for screen replacement, then installed the VWA 10.5.1 full version upgrade. I don't know if there is a relationship between these sets of upgrades, but thought to mention if it helps. Quote Link to comment
Bruce Kieffer Posted December 29, 2003 Author Share Posted December 29, 2003 Irving, Your situation seems to me to be a hardware problem. Mine is definitely a conflict with VW 10.5.1 since we it is the only program that while running causes my PowerBook G3 Bronze not to auto sleep. Quote Link to comment
Richard Posted December 29, 2003 Share Posted December 29, 2003 Bruce, are you running VW10.5.1 under OS 9.2? How well does it work? Haven't taken the plunge yet and wonder cause I have a Wallstreet 466 copper upgrade and haven't felt the need, bad readings on this tech board, to go to VW 10.. Opinions helpful! Quote Link to comment
Guest Posted December 29, 2003 Share Posted December 29, 2003 Please email this to bugsubmit@nemetschek.net. When the offices open again on Jan 2, someone will look into the issue. Quote Link to comment
Richard Posted January 4, 2004 Share Posted January 4, 2004 Any response from tech on this subject? Quote Link to comment
Bruce Kieffer Posted January 6, 2004 Author Share Posted January 6, 2004 Richard, I'm using VW 10.5.1 with OSX 10.3.2 only. Trash OS 9 a long time ago! I haven't heard anything further about the no sleep issue. Quote Link to comment
