Luis M Ruiz 245 Posted March 22, 2017 Now, I wish I can get to this level someday. @Stephan Moenninghoff Every student requires a master and we can all learn things from this good friend. 5 1 Quote Share this post Link to post
zoomer 1,073 Posted March 22, 2017 I think the Books in the Shelf are done by his Marionette Script. There was a Thread. For the building itself I see not much limits by using VW. Quote Share this post Link to post
grant_PD 253 Posted March 22, 2017 And herein lies the problem of "realism." Which is that it is just a style, like every other render style. There are various degrees of realism, and yet they all can be considered as realistic. I look at that rendering, and while I think it is good, and "realistic," I do not think it is accurate enough to be considered high end rendering. These days high end rendering is fascinated with layers of reflection, lensing, loose and casual props. It is a difficult conversation to have with clients, when trying to determine the how far they want to go. But I am encouraged by VW's efforts to keep up with rendering expectations. And I think they vastly undersell the other benefits of renderworks, which is to greatly enhance technical illustration with artistic flourishes. Quote Share this post Link to post
Phil hunt 75 Posted March 23, 2017 totally agree it's like an artist....everyone has his/hers own style which i think is brilliant...... Quote Share this post Link to post
Rummelplatz 2 Posted March 24, 2017 (edited) On 14.3.2017 at 4:19 PM, rDesign said: ^^^^ I completely disagree with this statement. Just because Vw uses the C4D engine does not mean that we have full access to C4D's abilities. Far from it, we only have access to a small percentage of what Cinema4D can do. For example, textures in Cinema4D can have multiple layers, which can add the dirt and grime that you're describing: Vw cannot have more than one texture layer. you are so wrong buddy...you can import textures from c4d with the shaders, you just can't edit them. ...stop assuming things you don't know anything about: . . . . . *drops mic* Edited March 24, 2017 by Rummelplatz Quote Share this post Link to post
PVA - Jim 2,388 Posted March 24, 2017 22 minutes ago, Rummelplatz said: you are so wrong buddy...you can import textures from c4d with the shaders, you just can't edit them. ...stop assuming things you don't know anything about: . . . . . *drops mic* Decals and layers of shaders are not the same thing. Decals are limited to a single face and can't interact with the rest of the shaders on the base texture like reflectivity and bumps do for instance. I appreciate your defense of the software's abilities, but this is definitely a limitation that we should seek to remove. (Also: While public discourse and debate is fine, there's no need to drop mics ) 2 Quote Share this post Link to post
zoomer 1,073 Posted March 24, 2017 For those who need a little more than RW and don't want C4D, (Texturing, Image File Output, ...) looking at Artlantis, I think it is a nice alternative for those who don't want too much complexity. Looking at Artlantis features, I find it quite interesting. If I got that right : - C4D like "file Exchange" (Reference Mode) - Support for latest VW versions - Affordable (If you don't need Animation and can contain yourself from InApp purchases) - Simple User Interface - Render Preview - Good Render Quality Quote Share this post Link to post
barkest 154 Posted March 24, 2017 Zoomer are you saying RW isn't the right way to go? Quote Share this post Link to post
zoomer 1,073 Posted March 24, 2017 No, I think you can get beautiful results pretty easy and it is always the best solution to get your visualization out of the App where you model and is kept with current changes. I like VW very much since VW 2017. Exchange works now well between VW and C4D, if your priority is on 3D and visualization. But C4D is one of typical 3D packages that you can spend your whole life learning. Artlantis UI tries to take complexity of rendering by assistant like usage. Standard FBX exchange to other 3D Apps has much more loss and therefore prevents from changes and updating your model. You better import once and do your changes in your 3D App of choice. If you only care about Visualization and no CAD at all. Quote Share this post Link to post
Andrew Davies 143 Posted March 25, 2017 My only real issue with Renderworks is texture mapping. Can never seem to get textures to map exactly how I want. Maybe UV mapping is the answer but I don't know enough about it Would also like to see a better way of outputting images (batch publish a render from a camera for example) 1 Quote Share this post Link to post
Andrew Davies 143 Posted March 25, 2017 On 22/03/2017 at 1:59 PM, Luis M Ruiz said: Now, I wish I can get to this level someday. @Stephan Moenninghoff Every student requires a master and we can all learn things from this good friend. That is very impressive Quote Share this post Link to post
Selin 43 Posted June 2, 2017 On 3/14/2017 at 11:19 AM, rDesign said: ^^^^ I completely disagree with this statement. Just because Vw uses the C4D engine does not mean that we have full access to C4D's abilities. Far from it, we only have access to a small percentage of what Cinema4D can do. For example, textures in Cinema4D can have multiple layers, which can add the dirt and grime that you're describing: Vw cannot have more than one texture layer. I'm late to the convo, but I slightly disagree with this. While Renderworks doesn't have the full capability of C4D (to be honest I don't think it should), it definitely does have textures with multiple layers. The limitation is, there's only one layer for each shader type. Also there's some layering inside a few of the shaders, which is mostly hidden from the user to keep the UI simple. As others mentioned before, C4D is one of those pieces of software that you can spend years learning. This gives the users a lot of control but things can easily get overwhelming. Our goal for Renderworks is to give the users enough control without losing much of the simplicity. Which is also the reason we've been focusing on exchange. It's great to hear that it's helped your workflow@zoomer Quote Share this post Link to post
Peter Kovacs 6 Posted June 7, 2017 I worked with Cinema 4D for years between 2007-2011. The best results came from an additional built-in render engine called "Vray for C4D". I do not think that I need to introduce Vray render engine to anyone who ever worked in visualisation industry. I believe that modelling in VW --> Exporting to C4D --> Rendering with Vray for C4D engine has no limits in photorealistic rendering. (Attached images were modelled in Graphisoft Archicad and rendered with Cinema 4D+Vray roughly 6 years ago) http://www.vrayforc4d.net 5 Quote Share this post Link to post
barkest 154 Posted June 7, 2017 On 2017-6-2 at 4:06 PM, Selin said: This gives the users a lot of control but things can easily get overwhelming. I am not sure about this. I am still a novice with C4D but using the physical renderer takes away a lot of options which simplifies everything. 4 hours ago, Peter Kovacs said: I believe that modelling in VW --> Exporting to C4D Agreed Quote Share this post Link to post
jmanganelli 65 Posted June 25, 2017 Luis' recent webinar tutorial on interior rendering is outstanding, not just with respect to use of Rendeworks, but also just for his excellent presentation and summary of a good rendering workflow. The results are also very, very good. 1 Quote Share this post Link to post
Luis M Ruiz 245 Posted June 26, 2017 15 hours ago, jmanganelli said: Luis' recent webinar tutorial on interior rendering is outstanding, not just with respect to use of Rendeworks, but also just for his excellent presentation and summary of a good rendering workflow. The results are also very, very good. So nice to read this comment, that makes my Monday morning. Thank you. Luis 1 Quote Share this post Link to post
Zeno 275 Posted July 26, 2017 On 15/3/2017 at 4:46 PM, Luis M Ruiz said: As promised, here is the file, v2017 Wes_Lamp_render.vwx.zip Thank you! 1 Quote Share this post Link to post
Hozie 1 Posted April 23, 2018 @Luis M Ruiz Hi Luis, you work looks outstanding. Could you send me a link towards your interior tutorial, i can't seem to find it on your profile. I am working on VW 2017, with RW. Thanks ! 1 Quote Share this post Link to post
Grethe Connerth 50 Posted April 23, 2018 ..." link towards your interior tutorial " ... I second that. G 1 Quote Share this post Link to post
Pat Stanford 1,520 Posted April 23, 2018 Sorry I can't resist: "Sit quietly and stare into the flame. Slow your breathing. Now focus your energy on your interior tutorial." 1 Quote Share this post Link to post
Luis M Ruiz 245 Posted April 25, 2018 I'll invite you all to check out this interior rendering webinar: http://www.vectorworks.net/inspiration/industry-webinars/see-it-to-believe-it-next-level-rendering-techniques 2 Quote Share this post Link to post
Grethe Connerth 50 Posted April 25, 2018 (edited) Thanks Luis, am already on it ... G Hi @Luis M Ruiz one questioning regards to the video - Is it available in a way where the video is not streaming? Reason - it takes quite a while to start and also when I stop the video or go back to listen again to some parts of the video it won't always start but I have to refresh the whole video and listen from the beginning. I know it may have to do with our provider and internet coverage here in OZ which is not perfect, but on the other hand I am not in the Outback but in Melbourne ;0)) ... Edited April 26, 2018 by Grethe Connerth Quote Share this post Link to post
Grethe Connerth 50 Posted April 26, 2018 Well done @Luis M Ruiz !!! I very much enjoyed the structure of the step by step orga behind setting up renderings. G Quote Share this post Link to post
Grethe Connerth 50 Posted April 27, 2018 (edited) Hi @Luis M Ruiz, hope you're well. May I ask which RW Setting the scene in your "See It to Believe It: Next Level Rendering Techniques" entails? 1) 34.30 Mins "Monotone Blue & Overlapping CAD Lines" 2) "Fading Effect" --> is this fade over look done in Photoshop or VW? 3) Also when it comes to Artistic RW Styles in the "Artistic RW Options" --> Style 'Art' there is one single blue-is/green-ish Image. Where is this image saved and can I change the colour of ti somewhere ? BTW - on an internal note re the files that I wanted to send you ... all of the Viewports imploded and crushed to being 'Wireframe' when I changed a Class. So I have to re-render everything before I can send them out, which may take a few days. Cheers, Grethe Edited April 27, 2018 by Grethe Connerth ... forgot a question ... Quote Share this post Link to post
