I was noodling around with a chair design and what I've discovered is that when rendering with a custom texture, what would be the face (though is actually the side of the chair) renders accordingly while the top of the chair ( the extruded part) renders funky. I get the difference between the surfaces, but how does one render the extruded part of a 3d object to match the face surface?
I tried the extract tool and since the extruded side is curved as you'll see in the attached pic, it's doesn't work that well.
mattOC
Is a better way to do this with edit subdivision?
Thanks for the help!
-M
5 answers to this question
