gogary
Wild Card for string match layer name, criteria in Worksheet Formula
In my Worksheet Database criteria Formula:
 I want to use a partial match on layer name -
to allow for future change to the name, according to each file's needs
using VectorWorks Designer 2017
The following is  not finished, as I'd like to filter for any layer name, containing the word "Demolition"
=IF((((L='Demolition') & (C='(Spaces-Existing-Non Living Enclosed')))=TRUE, space.area, 0)
New at vectorscript, Thanks to anyone with this knowledge
I don't think there is a way to use a substring in a layer name or a classname as criteria for a worksheet.
If you want to get fancy, you could write a Vectorscript that would present a dialog box of the layers allow a multiple selection and then have the script create the criteria for the database.  The hardest part will be the dialog box. There was another thread here recently that was talking about a selectable list of either layers or classes that would be a good place to start.
You can put multiple layers into a criteria is you edit the criteria manually.  Something like:
=DATABASE((L='Layer-3') | (L='Design Layer-2'))
The vertical bar indicates a logical OR so it will return things on Layer-3 OR Design Layer-2
Other fields like Name and (I think) Field values will allow you to use a wildcard of *
So another possibility is to write a script that will store the current layer into a custom Record.Field and then use that field with wildcards as the database criteria.  The problem is that if you move an object between layers (or add more objects) you will have to remember to rerun the script or manually update the field.
Wildcards for Layer and Class names would be a good wishlist item.
Pat
It does work for Classes.
I wonder if that's a bug.  I do this exact trick often with classes and it works great.
=DATABASE((C='Demolition*'))  will return everything in the class Demolition-Man, Demolition-Derby ,etc.
Never knew it didn't work for Layers.
mk
Interesting. I only tried it for Layers and then looked at the options for classes and did not see a CONTAINS option in the criteria builder and assumed it would not work for Classes either.
I doubt it is a bug on Layers. Layers live in an entirely different List inside Vectorworks. Ever noticed that you can have a Layer with the same name as a class or any other object.
Like I said before, It would be a good wish to have Wildcard for Layer names be acceptable criteria.
There's no GUI for using wildcards, you have to do it the old fashioned way.  I always thought that it worked on everything (I've done it with names of hatches fills).  I just never tried Layers.
But you're right.  I never thought of Layer names like that.  VW will let you name a Layer as "Door", but doing that with a Class name is a real bad idea.
I think we could start a nice wish list database criteria improvements :-)
Yes there is a wildcard function. Both Name and Symbol give the option for Contains or Does Not Contain and generate the * on both ends of the search term.
This is one of the many areas that VW could be improved.
You start the wish list and I will add to it as I come across things.
